ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Scan to mech to CAD
1 REPLY 1
Patrick_Aps_9121
483 Views, 1 Reply
Scan to mech to CAD
I am able to isolate out of a scan the portion that I want to re-model in CAD.
I could use scan to mech, to create an OBJ or RCM, but what then ?
How can I convert OBJ or RCM into DWG, DXF or DGN for furher use in plain CAD ?
1 REPLY 1
vidanom
in reply to: Patrick_Aps_9121
Hi @Patrick_Aps_9121,
We don't have an automated process for this at the moment.
Just Scan-to-Mesh (OBJ), or using the point cloud as reference for drawing the CAD geometry manually.
What you can try is export the mesh from ReMake as FBX > open in AutoCAD and export as DWG, which then can possibly be used in something like Revit.
Although I'm not sure how this model would look like, but I believe it's possible.
More appropriate way may be through Inventor, if you have that product available, with a tool like Mesh Enabler.
If you use Mesh Enabler I would recommend decimating the mesh to 2-4 million triangles before converting.
Mitko
Rail Community
