Recap/Remake file formats
Inventief
Message 1 of 17
Inventief
I'm using Remake now (and recap360) to process photo's to 3d.
The formats I can download consists of obj, fbx and rcm
After Remake stops on november 30th, will I be able to open the files from the 360 drive?
Especially the rcm files.
Or should I convert them to fbx/obj?
Secondly;
It's also  a bit confusing creating a new photo to 3D project on recap360, I get the message its moving to Recap photo with a link.
If I click the link I get the Recap Pro website, where you can download Recap Pro (which is what I did)
In the newly installed Recap, if you click Photo to 3D I get redirected back to the same recap360 dashboard in which I started.
Am I doing something wrong?
Replies (16)
Message 2 of 17
critesh
Hello @Inventief,
Answer: Yes, you can still download the files from A360 and you can open RCM in ReCap Photo, which was created in ReMake.
ReCap Photo will get installed with ReCap Pro. (You might have redirect here to install ReCap Photo http://blogs.autodesk.com/recap/introducing-recap-photo/)
Once you install ReCap Pro, look for desktop shortcut for ReCap Photo (Not for ReCap).
ReCap Photo enables Aerial workflow along with Object.
I hope this will help you to understand the difference.
Do let me know if you have additional questions.
Ritesh Chandawar
ReCap Pro, ReCap Photo, Dynamo, Fusion 360, Revit
Message 3 of 17
Inventief
@criteshThx for the explanation. But when I install Rcap Pro I wont get a RecapPhoto shortcut. Is this because I have Remake installed?
Message 4 of 17
critesh
Hello @Inventief
May I know the version of ReCap Pro?
Is it updated to the latest ReCap Pro? (Latest update to ReCap Pro will install the ReCap Photo)
Ritesh
Ritesh Chandawar
Message 5 of 17
Inventief
If I download via account I get version 2016.
After serveral updates; now I have 4.2 installed
Message 6 of 17
anil_mistry
Autodesk Support
Autodesk Support
Hi @Inventief,
I'm just checking in to see if you need more help with this. Did the suggestion that @critesh provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 7 of 17
Inventief
@anil_mistry Nope . Software keeps redirecting me to webpage, and no RemakePhoto to be found..
Message 8 of 17
anil_mistry
Autodesk Support
Autodesk Support
Hi @Inventief,
If you click Photo to 3D project option from ReCap Desktop then it will take you to Web browser. This is working as design.
Once you install ReCap Pro then will install ReCap photo and you will have an icon on your desktop.
Thank you and have a great day!
Anil Mistry
Message 9 of 17
Inventief
Oke.. still missing the recap Photo icon, but is the icon redirecting me to the website Aswell?
How do I open the rcm files?
And is it a problem to have remake installed on the same machine?
Thx.
Message 10 of 17
critesh
Hello @Inventief,
Can you please help me to check these two locations for your installation of ReCap Photo?
Your installed directory and the Control Panel menu.
Ritesh Chandawar
Message 11 of 17
Inventief
hi @critesh
Both locations do not show RecapPhoto.
I tried to install recapPhoto on another machine and with another account, and that worked.
Seems I can only try it when I select I'm an individual or buisiness user and not sign in with my account.
Is that correct?
Message 12 of 17
critesh
Hello @Inventief
Is your current account register as Student (educational), if yes, then for now you cannot use that account for using ReCap Photo, soon you will get other updates from us in Education usage.
Ritesh Chandawar
Message 13 of 17
Inventief
@criteshyep that seems to be the problem, I got it working now via another account.
Thanks for the help.
Message 14 of 17
critesh
Hello @Inventief
Happy to hear that the issue resolved and you are able to use ReCap Photo.
Keep using ReCap Photo and share your awesome work with others.
Ritesh Chandawar
Message 15 of 17
Inventief
@critesh
Thx! will do..
But to try you need to purchase cloud credits, right?
And the publish function is gone..
Message 16 of 17
critesh
Hello @Inventief,
Every trial account comes with 42 Could Credits, if you want more, you have to purchase.
Ritesh Chandawar
Message 17 of 17
Inventief
I see, so using more than 300 photos isnt possible..
