Recap Pro 2020 Importing Problems
Message 1 of 8
I have a problem when i try to import files to Recap. When i drag files to Recap, files always stuck at pending level. And when i try to index, again stuck at pending level. I already try uninstall  and reinstall, downloaded last version 6.1.0.71.
How can i fix this problem?
Thanks.
Replies (7)
Message 2 of 8
up
Message 3 of 8
yan.fu
Hi @Anonymous ,
What is the raw scan format?
There are some cases that the scan format might be new and ReCap may not support it yet, it will hang at importing phase.  For example, if it is Faro scan, you need to install latest Faro SDK to support scans from new scanners.
Could you share more information in the scans so that we can help or work on an update for it?
If you are willing to share one sample scan with us for investigation purpose, please message me the link.
Thank you,
Yan
Message 4 of 8
PatrickDavis20
Have you been able to use Recap successfully in the past?
What are the file formats?
What are the specs of your computer?
Patrick Davis
Twitter
LinkedIn
Blog
Message 5 of 8
Hi Yan,
Thanks for your answer, and apologies for i am late to answer this. I try to import .fls type scan data that i download from linkedin learning. The name of education is Recap Workflow. It must be work but in this computer it does not work. I really dont understand why?
Thanks.
Tolga
Message 6 of 8
yan.fu
You may need to install latest Faro Scene SDK to support the import of your Faro scans.
https://knowledge.faro.com/Software/FARO_SCENE/SCENE/SDK_File_Download_and_Installation_for_SCENE
Yan
Message 7 of 8
I just want to point out that installing the faro SDK fixed this for me!
I just spend 12k$ on this pc and it was stalling on a single fls file import for HOURS, nothing moved. I was going crazy !
Installing the sdk worked perfectly, only had to launch the .exe, bam, fixed
Message 8 of 8
vfirat1
Observer
Observer
hi, what do you mean with exe. bam  ?
