ReCap keeps crashing on 'index scans'
borisEJYFM
borisEJYFM
Community Visitor
Community Visitor
Using ReCap Pro v 24.0,I do the following:
  1. I create a new project
  2. Import point cloud
  3. I enter the project name and specify the folder.
  4. I select a .pts file
  5. I can import it
  6. After import I press `index scans`
  7. ReCap crashes
This is so mega annoying, I have no clue where to start debugging.
I have a RTX 3090FE video card and 32Gb ram. Im using Windows 11 pro.
When I set decimation to 100mm, the scan works, but the file becomes unusable as there is no accuracy....
The .pts files are between 192.000 and 510.000 KB in size.
tilo_pfliegner
Maybe you are able to get these pts files in some other, more optimized format like e57 or las/laz? You can also try to convert from pts to e57 or las/laz yourself using free tools like CloudCompare or lastools and try again.
borisEJYFM
Community Visitor
Community Visitor
Thank you for your reply. I tried CloudCompare, opened the .pts file and saved it as e57 file. I then open it in ReCap, set decimation to 10 and It will index, this works. However, only a small part of my pts file is 'there' / visible. This is very strange.....
When I open the e57 file in CloudCompare, the whole scan is visible.
tilo_pfliegner
You probably can't attach the e57 here, but if you send it to me some other way, I can take a look at it.
barmanr
Hi @borisEJYFM ,
Would you able to share the PTS file directly with us? If Yes, I will PM you a private one-drive link for sharing.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
