Hi @evogenesys ,
Are you referring to Publish from ReCap or sharing those files directly via some cloud drive?
Also, where are the files stored? Is it locally or in the cloud?
If the RCS files with question marks show up, it means it cannot locate the RCS files. You can click on one of the balls with the question mark and then a file browser dialog should open up. You can then point to the correct path on your machine.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
