ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
ReCap 2022 Network Deployment
4 REPLIES 4
sdoc
533 Views, 4 Replies
I am trying to deploy Recap 2022 to a lab for my school that I oversee.
I have done many lab installs, both with the classic way as well as with the cloud way of having autodesk create the installer online. When I download Recap 2022 and start the install process, it only allows a single computer install.
Is there any option online where I can download (or create) a network install for Recap 2022? Preferably if it would show up in my "Custom Installs" option under "Products and Services" webpage, it would make things easier.
Has anyone else been able to deploy ReCap 2022 via the network?
Labels (3)
4 REPLIES 4
barmanr
in reply to: sdoc
Hi @sdoc ,
I am not sure if this is what you're looking for but in manage.autodesk.com under Custom Install (Screenshot attached), you can create a deployment. Perhaps you can deploy it to a shared network location.
But if you already tried this and looking for a way to install via the network all at once, this is not possible at the moment.
Thanking You.
Warmest Regards,
Rishov Barman, Reality Capture
Rishov Barman
Reality Capture
sdoc
in reply to: barmanr
I didnt see an option in the Custom Install for ReCap.  Only Revit, Maya, AutoCAD, 3ds max.
I was just wondering if there was even an network install option or if I should try and contact Autodesk via chat
barmanr
in reply to: sdoc
Hi @sdoc,
You will need either a Serial Number or Autodesk ID subscription license for ReCap Pro to show up in Custom Installs (See image). Yeah, it would be best to contact Autodesk Support to see if Educational accounts can be used for Custom Installs.
Warmest Regards,
Rishov
Rishov Barman
Reality Capture
sdoc
in reply to: sdoc
Thanks for the info.  It now just showed up in the Custom Install field.  I guess there is couple of days of delay between the time I register and the time is shows up.
SDOC
Rail Community
