Real Views not placed correctly
jared.white
jared.white
We use cyclone to register data, and have realized that if the data is 'cleaned' in cyclone before exporting to an e57, the Real View bubble locations are messed up in Recap.  It seems like this is a bug to me. Has anyone else ran into this problem?
michael.riley
This is a new one to me.  I'll ask around.
In the meantime, would you be willing to share the data so that we can attempt to reproduce and fix the issue?  If so, I can sets up a box.com folder to facilitate the upload.
Michael
jared.white
Thank you, yes please send a link, and ill upload a dataset.
Jared White
3D Modeling Specialist
truescan3D
P: (513) 755-TS3D (8733)
[email protected]
www.truescan3d.com
Follow us at:
Facebook - Twitter - LinkedIn
Are you talking about in 3d view, or just in the small map overview in the top right corner?
michael.riley
You should receive an e-mail from box.com about an upload location shortly.
Michael
jared.white
Unfortunately the dataset that we have is extremely large (around 80GB), and I know it will be a long time to upload.  The RealViews seem to double the size of the RCP files.  Basically if we clean the data in cyclone, and then export to e57, some of the mirror balls are misplaced in the 3D view, and some are not.
We have also noticed that the naming of the scans from our scanner are not accurate inside of Recap.  It appears to nearly double the scan locations (Im assuming half are real views and half are the scans).  This creates confusion when using the scan dialogue because the scan names in the scanner are not related, and we cannot relate scans with our field notes.
michael.riley
Could you upload only the cleaned e57 files?  If they are registered already, we should see the issues that you are while cutting down the upload size considerably.
