Read RCP file
Read RCP file
pkramesh9HUWG
Message 1 of 13
Read RCP file
pkramesh9HUWG
Is there a way of reading the RCP file contents, Presently it looks like it is encrypted in Recap2026.
Thanks.
Replies (12)
Message 2 of 13
Pointdump
Hi @pkramesh9HUWG,
Welcome to the Autodesk Forums.
ReCap files are a proprietary format. What are you trying to see/do?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 13
pkramesh9HUWG
Thanks for your mail.
I make some measurement in "Recap Pro" like the diameter of pipes and some distance measurement. Can we get this values as text file so that it can be imported to the CAD environment.
Looks like these values are stored in RCP.
Alternatively, (I have to check this) when we open the RCP in AutoCAD can we get these measurement as seen in ReCap?
Ramesh.P.K.
Message 4 of 13
Pointdump
Ramesh,
"...when we open the RCP in AutoCAD can we get these measurement as seen in ReCap?"
Yes. The RCP file is intended to be used in AutoCAD and verticals like Civil 3D. You can use 3D Object Snap to either draw or measure.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 13
pkramesh9HUWG
Sir,
Sorry to ask this again. My question was, will the measurement made in Recap carried into AutoCAD when we open(attach) ReCap RCP?
Message 6 of 13
Pointdump
Ramesh,
"...will the measurement made in Recap carried into AutoCAD when we open(attach) ReCap RCP?"
I haven't tried, but no, I don't think so.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 13
kubitTilo
RCP is basically just a zip file containing an xml file, amongst others. You can check that xml file for your measurements:
Tilo Pfliegner
Message 8 of 13
pkramesh9HUWG
Ok. Thanks.
I wonder why this could not be open to users. Alternatively, if the Recap Pro SDK(which is presently not available) is made available it would be a great step forward to ReCap.
The reason for me is that I have been in this field of Laser scanning and modelling for the last 25 more years and was trained on Cyra's first few commercial scanners. I can provide some valuable inputs..:)
Message 9 of 13
kubitTilo
There is the so-called "Reality Solutions SDK" available from Autodesk. Not sure if you need to be an ADN partner to get access to it.
Tilo Pfliegner
Message 10 of 13
pkramesh9HUWG
Thanks for this reply and info.
Message 11 of 13
pkramesh9HUWG
I have checked this on the AutoCAD website, The Reality Solutions SDK is available which has to do with 3D photos and photogrammetry. The Recap Pro SDK which deals with laser scan data is not available presently.
I just needed the limit box and cloud segment based on limit box to be made available thru the API or SDK.
Message 12 of 13
kubitTilo
I'm pretty sure the Reality Solutions SDK is exactly what you would need. From their website:
Tilo Pfliegner
Message 13 of 13
pkramesh9HUWG
That is good to know. We will license this SDK and will let you know also.
Many thanks for now.
Ramesh.P.K.
