"otimizing" Why is this still so slow.
arron.craig
Message 1 of 10
arron.craig
I've been waiting for a project to optimize for 3 days now. Based on previous larger projects I expected this to take about 12 hours so I started it on a Friday. I cannot fathom why this is taking so long.
The project is only 32 scans, 55GB and is from an RTC360. I deleted a little bit of noisey data, probably about 5% of the scan and then saved (not saved as), choosing to optimize.
It's only using 13GB of ram and 8% CPU (sparodic usage on 4 cores) and 8% GPU, no disk activity.
Recap Pro 2021 (cant confirm version while it's stuck optizing)
Intel Core i9 10900K
64GB DDR4 3200 RAM
Samsung 2tb NVMe
Nvidia RTX 2070 SUPER
Has anyone seen it take this long? Am i best off killing it and starting again?
Replies (9)
Message 2 of 10
yan.fu
Could you check if files are kept written into your temp folder to see if it is still running of or might just hang there?
C:\Users\<USERNAME>\AppData\Local\Autodesk\Autodesk ReCap\import_output
Message 3 of 10
arron.craig
Hi @yan.fu, I just got into the office and it has now finished, ended up taking just over 4 days. The project file has reduced from 55GB to 53GB....
There are no files for this project in import_output (just some old files from March)
Is this long run time expected behaviour?
Message 4 of 10
arron.craig
@yan.fu Is the long run time like this expected behaviour?
Message 5 of 10
yan.fu
Hi @arron.craig ,
It depends on the area of the deleted points and how complicate the selections are.
Also, because there are a lot of I/O to the disk so the performance of the drive also matters.
Yan
Message 6 of 10
arron.craig
@yan.fu As per my original post, I am not getting any measurable I/O on the disk, it's usage sits around 0%-1% while "optimizing".
It's an NVME drive with 3000MB/S read/write and is a seperate drive to the OS.
I deleted about 2GB worth of points via very simple rectangular selection.
Message 7 of 10
yan.fu
Thank you for your information. We will do some investigation from our side for the case you mentioned.
Yan
Message 8 of 10
Les_Gustin
I am having similar issues. I Created multiple regions with no performance issues in the file until optimization is run. Once Optimization is finished regen and movement around the point cloud is very slow. This also translates to the Revit file it is linked in.
Message 9 of 10
arron.craig
Performance after optimising for me is no different, How long did optimising take you though?
Message 10 of 10
Les_Gustin
It is a 35 scan point cloud that has been cropped and consolidated to a single recap scan. The regions were created after consolidation. While no where near your time frame. It took 15mins to Optimize the 1.8 Gb point cloud with 4 very small Regions with no change in file size afterwards but the point cloud performance was unusable after optimization.
i9-9920x
64 GB of Ram
Quadro RTX 4000
WD Black SN750 NVMe
