ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Problems with target-less survey points
1 REPLY 1
Stephanie_bergeron
288 Views, 1 Reply
I am experiencing problems with target-less survey points: every survey point I manually enter ends up at the wrong spot and one on top of the other....what gives? I tried several ways including truncating, importing an xyz tab delimited ascii file, a xyz space delimited ascii file, a pts file (none of the imports were successful and gave me an error message), I don't know what else to try...
I'm using Recap Pro version 5.0.0.40 and on Windows 7 and used a different computer running Windows 10 and the same issue arises.
1 REPLY 1
Hi @Stephanie_bergeron ,
Are you referring to arbitrary XYZ coordinates for your scene? When you submit your project, what is your input coordinate system?
Warmest Regards,
Rishov Barman
QA Analyst Reality Capture
Rishov Barman
Reality Capture
Rail Community
