Problem with Update Origin
Message 1 of 16
I am trying to update my scan project which appears to have registered with a slight angle. I have used the 'Update Origin' tool within recap multiple times trying to better understand how it works. I am selecting points that make up the floor surface but the origin 'gizmo' is forcing the z-axis to remain perfectly vertical instead of the slight (~3 degreee?) skew necessary to correct the scan. Any ideas would be appreciate
Replies (15)
Message 2 of 16
amorap
hello form Spain Jrostar
You can update and modify your Z axis in ReCap.
But beware of this: when you specify a direction think that you have to specify a NORMAL VECTOR to a surface. This means that when you are setting the proper Z direction you must select the horizontal plane, the floor, the pavement or some equivalent.
The solution could be:
- Select the icon "update origin"
- Press "tab" to skip setting origin and jump to setting Z direction.
- Select an HORIZONTAL PLANE, like the floor or the pavement. Then your Z axis will be updated to be orthogonal or normal to that plane.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 3 of 16
bim
What you described is what I have tried and the expected workflow.
However, when I select points in the HORIZONTAL PLANE of the floor slab, the angle of the z-axis does not update. It sticks straight up despite the floor slab being at an angle when viewed from a section view
Message 4 of 16
Sorry, I was logged into the wrong Autodesk account... above response is from me
Message 5 of 16
amorap
I suppose that, dont worry Cat Happy
I'm not sure what are you doing when you tell that are selecting points over an horizontal plane.
I have done right now and I only need to select a point to set the horizontal plane.
Its important to be sure of this: you have to selec only a point over the horizontal plane, ReCap detects the "plane" sorrounding this point.
regards.
Augusto Mora
Message 6 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the ReCap forum!
I was wondering if you have tried adding survey point to possibly get a better result. I would suggest to place several points on the floor, distributed across the dataset, setting all Z=0 or some constant value and see if that works with what you are trying to do.
Thank you and have a great day!!!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 7 of 16
Is there some document or video that could show me how to place points and force their coordinates? I am unsure how to add survey point data. Thanks!
Message 8 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, review this articles to learn more about how to add Survey points to point clouds:
Let me know if this helps.
Anil Mistry
Message 9 of 16
Just to be clear... the proposed solution is to create a survey file with a series of x, y & z points and then 'assign' them to points within the recap model?
Since I did not shoot the project with targets and relied on the scan to scan registration, I do not have clear targets to 'pick' and assign survey points to. I do not think this workflow will work since I am not simply bringing the floor into flatness but I need to rotate the entire scan set together so walls, floors & ceilings all square up properly.
I will attempt the 'update origin' tool again to see if I can get Recap to 'see' the floor plane
Message 10 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am sorry that previous suggestion didn’t work for you. How about aligning the Z axis by clicking a point on the ceiling and then flipping the axis instead using the ground.
Anil Mistry
Message 11 of 16
Attached is a screen grab so you can see the process I am trying...
You can see the angle of the scan
I activate the Update Origin command and select the floor slab. I believe the angle is too close to 'flat' for it to work properly
You can see when I select a wall, it 'flips' the origin but when I pick the floor slab again it goes back to ortho instead of aligned with the slab to match the angle. I have tried putting the origin at the 'high' point in the angled slab and picking the 'low' point but still no luck. Is anyone seeing anything wrong with my attempted workflow?
Message 12 of 16
Youtube link for video... https://youtu.be/Kgxlpo5IWnY
Message 13 of 16
I was able to stumble my way through the problem... Ultimately here is how it was fixed (with help from Anil)
Placing a series of Survey Points where I kept the X & Y values the same, but changed the Z value to 0. You may notice this was suggested previously, however there was little clarity provided in HOW this was done...
1- Enter Project Registration Mode
2- Enter a Scan's 'RealView'
3- Select a point on the floor slab
4- Click 'Create Survey Point'
5- Copy & paste the X & Y values from the point information above into the Survey Point information below
6- Set the Z value to 0
7- Label the Survey Point (I did simple numerical order... 1, 2, 3, etc)
8- Click 'Save'
9- Make sure the Green Dot in ReCap turns to a different symbol with the label you gave it
10- Repeat for as many survey points as you need
It was originally suggested to place 3 points. This was not enough for my scan data set. I placed 6 spread out at the various edges of the scan data and had good success. I hope this helps someone else!
Message 14 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you so much for detail reply. I just want to let you know that development team did further investigation and they were able to duplicate this behavior in test environment. They will correct this behavior in next update. We will give you an update you via forum and product release notes. For now, as workaround use above mention steps in @Anonymous’s reply.
Anil Mistry
Message 15 of 16
pkramesh
I do not get the window shown for update origin(Original). I have this window(Myscreen) instead. Any idea?
Message 16 of 16
barmanr
Hi @pkramesh ,
ScreenOriginal in your image is the new Enhanced Update Origin Tool released last week on the 1 Oct, 2025. You would need to apply the latest update service pack 2026.1.0 over ReCap Pro 2026 version. You can download the update via Autodesk Access or https://manage.autodesk.com/products/updates.
For info in the key features in ReCap Pro 2026.1 update: https://forums.autodesk.com/t5/recap-forum/autodesk-recap-pro-2026-1-release-notes/td-p/13835192
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
