ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
PORQUE TARDA TANTO EN 1% INCLUSO CON SOLO 20 FOTOGRAFIAS?
3 REPLIES 3
374 Views, 3 Replies
Hola comunidad, estoy cargando en el recap 20 fotos y llevo mas de 30 minutos y se quedo en 1%, habrá alguna solución para esto, no debería de pasar si solo son 20 fotos.
3 REPLIES 3
anil_mistry
anil_mistry
Autodesk Support
Autodesk Support
Translation (via Google Translate):
Hello community, I am loading 20 photos in the recap and it took more than 30 minutes and it stayed at 1%, there will be some solution for this, it should not happen if there are only 20 photos.
@anil_mistry translated your question per the above as this is predominantly an English forum.
Thank you for participating in our Community! Would be able to let me know what version of ReCap Photo you are using? Are you using EDU licensing or have subscription for ReCap Photo?
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Anil Mistry
anil_mistry
in reply to: anil_mistry
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I’m just following up to see if you were able to gather the information I had previously requested to assist me in troubleshoot your issue.
Anil Mistry
Hi @Anonymous,
Anil Mistry
3.PNG1.PNGHello everyone there.
Ive been waiting for more than 16 hours after 850 Phantom 4 Pro Images were uploaded, with GCPs, and Autodesk ReCAP Photo still showing me "100%" and "Uploading".
Is there a way for me to know what is happening?
Images are in WGS84, as its from DJI drone. GCP are in thecoordinate system of the project, which is Sirgas 2000 UTM 22 S.
Rail Community
