point cloud placed at 0,0 coordinates
aytug.gulec
aytug.gulec
I created my aerial project with 146 photos, and set gcp's in local coordinate system i created and added cslibrary before. Also set target coordinate system as my local cs.
In the end my orthophoto located at the right place, but point cloud placed at 0,0 coordinates except elevation is true. I don't undrestand what's the problem.
Yoshiyuki_Miyauchi
@aytug.gulec
You need to give the correct coordinates to the point itself using different software.
For example, try giving the coordinates using software such as Leica Cyclone.
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Yoshiyuki Miyauchi / 宮内よしゆき
openBIM Architect
ONESTRUCTION Inc. Co-Founder & CTO
buildingSMART Japan IFC利用支援小委員会 委員長
bSI BIM Professional Certification | BSI BIM Project Information PRACTITIONER | BSI BIM Asset Information PRACTITIONER
Civil User Group認定インストラクター
[email protected] | TEL:050-3528-8052
Twitter|LinkdIn
aytug.gulec
My gcp coordinates are correct in local coordinate system. I'm not sure why i need to do it with different software but, when i convert them to EPSG 3857 and reprocess at the recap photo, my problem has solved.
I want to do with my local coordinates too, but it placed at 0,0.
