Dear all, I need a workflow and a bit of guidance on how to import an NWD model into Recap Pro and make both lined up. When I import the model it shows that it has been successfully imported but I can't see the model. One issue may be different coordinates, which I don't know how to fix. I appreciate your views, please. Thank you.
Solved by anil_mistry. Go to Solution.
Hi @Anonymous,
Thank you for participating in our Community! You can only view Attach Navisworks Project in RealView. Are you not seeing this project in RealView. If not then please watch this video for more information, this feature starts around 20:00. Let me know if this helps.
Thank you and have a great day!
This reply has been edited by the moderation team as the link was no longer valid.
This does not help. I can see the model, but it does not line up correctly. How do I manipulate either the point cloud or the Navisworks file in Recap Pro so that they line up?
