So I imported an NWD into a RCP I had. The NWD was jus just some extra pipe to fit into the piping in rooms that I had scanned. it looked great, worked perfect.
Then I added an NWD to a larger project, with more scans. this NWD was a whole building shell and all rooms inside, everything. this model does not show, unless I look up. when I start looking down, it disappears.
We also tried this with another model, on the same scan, of just ductwork, and it only shows when you look one direction. See screencast below. Thinking maybe the file size is too large? too many scans? the NWD was about 16MB.
maybe im missing a setting
Solved by anil_mistry. Go to Solution.
I'm sorry to hear about the issues you are having.
We are currently investigating the issue. Do you have a project that you could share with us in order for our devs to replicate the issue?
James
How did you manage to import a NWD into Recap? I've tried it in the latest version and it messes up everything.
So when I append my point cloud and a 3d Model into navisworks they merge with no problem, using the same WCS. But when I save that model as a NWD and later import it into Recap it is not located where it's supposed to be... Any thoughts?
Hi @Anonymous,
I replied to your original thread in here:
http://forums.autodesk.com/t5/recap-360-forum/nwd-display-issue/td-p/6613247
Mitko
Hello All,
Thank you for participating in our community! We are aware of this issue and engineering team is working on resolving this issue. We will provide you an update as soon as one is available.
Thank you and have a great day!
Best regards,
Hi.
Any progression on solving this problem yet?
I have a .nwd file containing a set of five buildings. On import in ReCap i get a message that says: PROJECT SUCCESSFULLY LOADED, but nothing is showing. All of the buildings are products from scandata and I would like to compare the scans and the model in the ReCap software.
-MW
throw them both in navis first to make sure they are in the correct location
and remember, nwd only shows in realviews
