Is there a way to export an individual region? Or at least all regions but the Unassigned Points region? Thanks.
Solved by Patrick_Aps_9121. Go to Solution.
Usually the export command will export whatever is displayed so if you want to export an individual region you just have to hide the other regions an the unassigned points region.
Hi Bryan,
You can export each Scan Region to a separate RCS file using the "export" button in the project navigator Scan Region tab. I have attached a screenshot for clarity
Thank you,
Marc
Marc Zinck
Software Development Manager
Autodesk - ReCap
It should be possible, see my question on the forum.
https://forums.autodesk.com/t5/recap-forum/export-1-region/m-p/6856094#M7936
however, there was a bug in 3.2.1.2 that it always exported all regions.
If you let us know how the current version is performing ?
Hi Patrick,
We fixed a defect related to region export with hidden regions in ReCap 4.0.0.28 and later. Prior to ReCap 4.0.0.28 the visibility state of regions was not respected when using the region export feature. This fix was unfortunately not indicated in the release notes for ReCap 4.0.0.28
Marc
Marc Zinck
Autodesk - ReCap
Good news,
Version 2018 (4.0.0.28) is exporting only the visible regions when exporting to RCS files.
