need 3d laser scan file
hi every one i'm starting to work with autodesk recap and i need 3d laser scan to learn. can any body help me and share 3d laser scan file  with me.
thanks alot.
TomislavGolubovic
There's a sample model that comes with the software. You'll see it when you open ReCap
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
MarcZinck
A sample project ships with Autodesk ReCap and should appear in your recent projects list when you first install the package. The project can be found at the following location on your workstaion "ProgramData\Autodesk\Autodesk ReCap\Sample" and is called AutodeskReCapSampleProject.rcp.
Thank you,
Marc
Marc Zinck
Software Development Manager
Autodesk - ReCap
