Multiple Users
Multiple Users
JFN_KSH
Multiple Users
JFN_KSH
Is it possible, for two or more users, to open the same .RCP files at the same time? From a shared directory, stored on a server...
We're currently having some issue with Recap where the software would hang in the opening process... Trying to troubleshoot right now...
Thanks.
Maksim.Melnikov.BY
Hi @JFN_KSH
Multiple users will not be able to open one project at the same time.
You can try creating a blank project on each user's computer and importing RCP from the server into it.
When a file is changed on the server, users will see the changes in their files.
Maksim Melnikov LinkedIn | Instagram
Autodesk Solutions Expert
Autodesk Certified Instructor
JFN_KSH
Our users are typically have limited HDD space on their local workstation (250GB). Using this method, will it copy the support folder to their C:\ drive? Our project is about 460GB... Thanks!
Maksim.Melnikov.BY
Unfortunately, I have no way to check, since I work locally or in the cloud.
But I noticed that the empty project support file into which the main file is imported is much smaller.
I did all this on my hard drive, try uploading a small project and test my theory.
JFN_KSH
Ok, I tried it & this is a great workaround... The local support files are much smaller... It does not copy all the support files locally, which is great... Thanks!
