Mesh option grayed out from ReCap project
I am using a structured scan, but still have this problem. It's weird because I have meshed things using this exact scan data already, and it worked fine. But now, the mesh option is grey.
Thanks!
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our community! Are you importing E57? If you are then check if all scans are structured scans. If they are not, then remove unstructured scans from the mix and try again.
Would you be able to share your project data for further investigation?
Thank you and I look forward to your reply.
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if my post helped you with your question.  Please let me know if you need additional assistance or have further question.
Thank you,
Anil Mistry
