Mesh Failure
Mesh Failure
Kimpten
Message 1 of 17
Mesh Failure
Kimpten
I have several scan models that continue to keep failing on the mesh creation. I am looking for more suggestions on what to try to see if there is something that is causing them to fail. These scans were PTG Files and are structured as well as registered.
I have tried
Large Coordinates (location of my scans)
Updating Origin Location to middle of my scans.
Perspective mode and Orthographic mode
Changed Limit Box sizes to be within the 30m, have gone all the way down to 5m.
Clipped out only a small piece to see if that are would mesh.
Changed the Name of the Mesh
Changed Quality of the mesh.
Reimported entire project to see if something was corrupt.
Any other ideas on what may be causing the issue.
Replies (16)
Message 2 of 17
ryan.frenz
One thing to check: we have recently found an issue where mesh generation can fail if the scan names contain spaces or special (non-ASCII) characters.  A fix is in the works.
-Ryan
Message 3 of 17
Kimpten
I appreciate the information. I never would have though a space would cause an issue. I have attempted the mesh process again after removing any spaces or special characters, and was presented with a mesh failure again as a result.
Message 4 of 17
ryan.frenz
To be clear - the problem is with the scan names, not just the mesh/project name.  Did you rename the input scans, and recreate the project from them?
If so, and you still get failure, there may be another issue here.  Can you share your project name and Autodesk account username?  You can send me a private message.  I can forward to our folks who may be able to see what's going on.
-Ryan
Message 5 of 17
Kimpten
This solution did work for being able to get me a mesh created. However my Mesh is now coming out at 0,0,0 when the model in recap is still are proper coordinates. I have tried clicking the reset coordinates that did not help.
Message 6 of 17
ryan.frenz
Indeed, this is not possible with the Beta service.  Each mesh will have its own coordinate system.
It is usually recommended to keep the project in point cloud (ReCap) format if strict coordinates are required.  I'm curious what you're trying to do that requires the mesh on specific coordinates?
-Ryan
Message 7 of 17
And cloud credits drain away.  Still think it's a good idea?
Message 8 of 17
ryan.frenz
I don't follow.  Nothing discussed in this thread costs any cloud credits.
Message 9 of 17
I could not mesh my project because my Cloud Credits were zero (which was not true and an Autodesk/Dealer snafu).  I need credits to mesh.
That said, obviously I don't know what I'm talking about.
Message 10 of 17
Kimpten
So during the Beta service, the coordinates are not transferred over and the mesh created at the coordinates. I did not realize that was the case. The part that has me confused on this matter was this scan data to mesh in question was not the first set of data that had been processed.
I had a couple of other point clouds that were processed using the same steps I had performed and the mesh was created at the coordinates the point cloud were on. That was what I wanted and everything went great. Then I had the problem above that was fixed by removing the space in the scan name as suggested. So now this mesh is created but will only create at 0,0,0. which if that is what the program is supposed to do that is great, just wondering how I got meshs before (1 week ago) at my specified coordinates.
I am happy with the service either way just wondering how two different results on location of the mesh that is created.
thanks,
Message 11 of 17
ryan.frenz
@Anonymous: Sorry for the short answer, but the thread is diverging a bit.  It's possible I'm confused.  There are two ways to create a mesh in the ReCap portfolio:
  1. The ReCap Pro feature to create a mesh from point cloud ('Object Mesh').  This is in Beta and has no cost.
  2. The Photo-to-3D service, available via the ReCap web app (recap360.autodesk.com) and ReMake.  This service creates a mesh from a series of photographs and costs 5 cloud credits for high-resolution meshes.
Are you referring to #1 or #2?  If #1, that sounds like a bug.  Could you provide a screenshot?
-Ryan
Message 12 of 17
ryan.frenz
@Kimpten Interesting.  It's possible that the coordinates are maintained in certain cases.  I'll look into it and let you know what I find.
-Ryan
Message 13 of 17
I did #2 a couple of years ago.  I ran extensive tests on a model car and then got tricky and sent renders of a 3D car to the cloud to see what I got back.  Texture got interpreted as changes in elevation.  The roof and hatchback window had large, unexplained sinkholes.
#1 I did recently.  Cost me cloud credits to send it off, so my experience does not mesh with your comments.
Message 14 of 17
BarrydSullivan
Currently if you attempt to create a mesh with spaces in the name and it fails, you are still charged Autodesk credits for the attempt.  Not sure why if Autodesk is failing the attempt that we should be charged for it.
Message 15 of 17
barmanr
Hi @BarrydSullivan ,
Is this scan to mesh or Aerial projects in ReCap Photo? Spaces should be handled correctly. Would it be possible to provide me with the project name of your failed mesh so that I can check the backend logs for investigation?
Also regarding Cloud credits, you should be getting auto refunded for any failure or crash in the pipeline. You only do not get refunded if there was a result but it was garbage due to input error. If the refund hasn't come in, please contact support and they will initiate a refund.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
Message 16 of 17
BarrydSullivan
Barmanr - Community Manager,
To date we have not received the 4 cloud credits from the failed mesh conversion for our cloud file in Recap. I am also looking at converting another mesh on a lidar file currently and will let you know if that doesn't go through properly. To your query, we are using Recap Pro to convert the lidar file to mesh. The project name of the failed mesh is 'Ucluelet_Mixed_Use_Mesh".
Message 17 of 17
vandhere
Observer
Observer
How do you rename the input scan? I am getting the same error when I try to convert the point cloud into mesh. "Mesh Failure".
