If I try to export with decap v7.0.1.22 command line like "Decap.exe --importWithLicense outputFolder projectname --unify source" - and open the rcs file in Revit - select Normals, the PC is just gray. If I use Recap UI and export to RCS, normals works fine in Revit. Is this a bug in Decap or am I using wrong command line parameters?
