I have one coordinated point from a P40 scanner, and one uncoordinated point cloud from a BLK360 scanner. The scan areas overlap. I tried coordinating the BLK data using targets but it will not recognise the targets when I try to pick them. I also tried picking targets in the P40 data and this did not work either.
I then tried registering the uncoordinated BLK data to the coordinated P40 data. The registration worked but it did not keep the coordinates of the P40 data and instead became arbitrary.
How can I solve this issue? Is there a way to set a home scan world, or fix the coordinates of one of the scans?
Solved by miguelantunes1992. Go to Solution.
https://help.autodesk.com/view/RECAP/2018/ENU/?guid=GUID-76535CD1-8BBA-43CD-82F3-574B9B8B4D62
You have to unite the non georeferenced with the geo, never the opposite
Open the p40 scan project, regist the blk scan and then unite
Miguel Antunes
Go here, and save three points from the uncordinate scan then goback to the project, I think this result
Yes. It indicated that there was a good registration. Upon inspection it was in line with the original point cloud. However the coordinates were incorrect, they were now arbitrary.
Is there any way to adjust the settings in Recap? Maybe I can choose a scan to be the reference scan that will not move, or a way to fix the coordinates so they won't change in the main point cloud?
Do you mean that I should choose targets in the uncoordinated scan? I can not get Recap to recognise the targets in either point cloud. One point cloud was recorded using a Leica P40 scanner (this is the coordinated data) the other recorded using a BLK360. It will not recognise the targets in either point cloud. I used standard leica 4.5 inch targets.
I will make this:
Open the georeferenced scan , import the non-geo , resume registration, merge, and then choose 3 points in registration and save and the result is one project with the first coordinates
Sorry don't know
@miguelantunes1992 wrote:I will make this:
Sorry don't know
Apologies I don't understand what you mean by "and then choose 3 points in registration and save..."
I have done as you suggested and I believe it is working, I still need to check the accuracy of the transformation but I think this has solved my issue.
Thank you very much for your assistance.
