How to convert RCM format to RCP format?
Message 1 of 10
I want to export ReCap Photo programme's 3D model to ReCap Pro for 3D Model importing to Revit. I exported PTS format then i open in ReCap Pro but, model has insignificant few points.
After, I import RCP format in ReCap Web. But, I faced error.
rcp açılmayan.JPG4
How can I transform RCM format to RCP format?
Accepted solutions (3)
Replies (9)
Message 2 of 10
gustavo_bergoya1
This happen because you RCM file y very small.
You must scale your Mesh in Recap Photo and then export to PTS.
With correct scale you RCP will have the correct points or pixels in Recap
Regards
Message 3 of 10
gustavo_bergoya1
Message 4 of 10
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! At this time, you can do following to convert RCM to RCP to view point cloud model in Revit:
  1. Open RCM in ReCap Photo
  2. Export this model to PTS
  3. Create new project in ReCap pro and Import this PTS
  4. Save as RCP or export as unified RCP/RCS to view in Revit
Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 5 of 10
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 6 of 10
Hi, similar issue but not resolved for me....
Don't run ReCap Pro, only ReCap Photo....
Old workflow was crazy but worked :  "import obj to ReMake & save as .rcm  … export .rcm to ReCap360 & export as .rcp pointcloud … import .rcp pointcloud to Revit"
Since software merged to "ReCap Photo", I cannot find a usable workflow to convert from .rcm to .rcp for Revit.
Can you help please?
Message 7 of 10
It's ok, I worked it out myself.
Still a crazy workflow Woman Frustrated
Message 8 of 10
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your reply and I am glad to hear that you were able to resolve this issue. Please, let me know if you have any other questions or concerns.
Anil Mistry
Message 9 of 10
 What was your workflow solution to this problem?
Message 10 of 10
I am tring to import a model .rcm ( created from photos within recap photo) in to a recap project .rcp.
There does not seam to have a direct workflow!
can anyone assist?
Thx's
