Deleted points not deleted in e57 export
Hi Support,
I have deleted points from a scan, then saved the project as a new one to ensure the points are permanently deleted (and they are no longer present when the project is loaded in ACAD, Navisworks, Revit, etc.), and then exported a complete e57 file including the per-scan information.
When I import this scan into other programs (including Recap), the deleted points return.
Is there a way to keep per-scan information upon e57 export, while ensuring deleted points are not present?
I have used Recap Pro 5.0.2.41 for this test, but have seen the same in earlier versions.
c.barribaud
I have the same problem
yan.fu
Hi @c.barribaud ,
ReCap doesn't remove deleted points from single e57 scan export yet.
The points are deleted only when you export the whole point cloud to unstructured e57 file.
Best,
Yan
efaustoD3RAG
I believe this is fixed now, but only if you save your project in ReCap and optimize the point cloud before exporting.
Edit: I was wrong... struggling to remember how I did this last time
