Coordinate system in Recap Photo
Message 1 of 10
Hi!
First time using Recap Photo for a flight made with an UAV.
Gathered the photos (138) and when selecting the GCP noticed that the Portuguese coordinate system is not listed : ETRS89 PTTM06 (EPSG 3763).
Is it possible to add it to the application?
If not, how can I create the GCP? They were created in the field using a GPS with the portuguese coordinate system.
Thank you.
Replies (9)
Message 2 of 10
Karsten.Saenger
Autodesk Support
Autodesk Support
Dear @Anonymous,
Recap Photo uses the same shared Autodesk coordinate systems as all other Autodesk programs (Civil 3D, InfraWorks, Map 3D, AutoCAD, etc.) use as well.
The Portuguese coordinate system EPSG 3763 is not part of the coordinate system database.
In Civil/Map 3D use MAPCSLIBRARY to open the coordinate system database to search for all available system.
You have some options now:
  • With Civil/Map 3D create the coordinate system you want to use. You will also need to define the transformation settings
  • The new custom coordinate system can now be used to transform your GCP points into an Autodesk known system, i.e. ETRS89.UTM xx
  • The transformed coordinates can be used in Recap Photo
  • Alternatively, use any (online) software that is able to transform for GCP points to an Autodesk known system before creating the Recap Photo project
Karsten Saenger
Message 3 of 10
Message 4 of 10
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous,
I understand your point and will double check with the Map 3D team who "owns" the coordinate systems features at Autodesk, to see if EPSG 3763 can be added to the CS library.
Karsten.
Karsten Saenger
Message 5 of 10
mferrer
Observer
Observer
Buenos dias.
El problema que describe el usuario Miguel Guimarães, lo tengo yo en el presente. Han pasado 8 años y todavia no han incluido ese sistema de coordenadas. En mi caso es para exportar ficheros a kmz. Es muy importante para nuestro trabajo, y nuestro cliente.
Espero resolvais pronto el asunto.
Gracias por vuestra atencion.
Message 6 of 10
Karsten.Saenger
Autodesk Support
Autodesk Support
Hello @mferrer
I can understand your frustration since 8 years is a very long time.
Please note that the topic of coordinate systems can't be solved on the ReCap (Photo) side.  All Autodesk coordinate systems are shared by different Autodesk products.
I might have some good news: EPSG 3763 is planned to be added to the Autodesk Coordinates systems with one of the next updates for AutoCAD 2026. Once it's added there, you should also be able to select it for any online processing in ReCap Photo.
Karsten.
Karsten Saenger
Message 7 of 10
mferrer
Observer
Observer
Gracias, espero ansioso esa actualizacion.
Gracias.
Message 8 of 10
Pointdump
Hi Miguel,
I've attached ETRS89/PT-TM06 (EPSG:3763). In Civil 3D or Map 3D use command MAPCSLIBRARYIMPORT to add it to your coordinate systems.
https://help.autodesk.com/view/MAP/2025/ENU/?guid=GUID-E5162E03-C254-49EF-A4DE-A88F43447330
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 9 of 10
mferrer
Observer
Observer
Muchas gracias Dave.
Ha funcionado correctamente, muy buen trabajo, y muy rapido.
Enormemente agradecido.
Saludos.
Message 10 of 10
bcookJKFDP
Thank you!
