Convert RCP file to XYZ format
Message 1 of 16
Hello all, I have done up a scanned data in .rcp format, how do I convert it into .xyz format?
Thanks in advance!
Replies (15)
Message 2 of 16
gerald_chin
Hi @Anonymous,
From ReCap Pro, you can export your .rcp file from the export menu to .pts and subsequently, you can open the .pts file in ReCap Photo and export it to .xyz from the export menu in ReCap Photo.
 ReCap Pro Export MenuReCap Pro Export MenuReCap Photo Export MenuReCap Photo Export Menu
Let me know if you need anymore help!
Cheers,
Gerald Chin
Senior User Experience Designer,
Autodesk Vault
Message 3 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @gerald_chin provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
Message 5 of 16
michael.reuter
Anil: I just tried to perform the same workflow that you & Gerald suggested.
I can export as a .PTS from Recap just fine.
However, when I try to import a .PTS into Recap Photo (version 18.2.0.8), I'm not able to.
The only files I can export from ReCap are the following FIleTypes:
RCP
RCS
PTS
E57
The only files I can import into Recap Photo are the following FileTypes:
RCM
FBX
OBJ
PLY
STL
STLb
STLa
Once I've gotten a file started, I can export to XYZ, however I can't bring anything in from ReCap directly. Please help. How can we take a .PTS into ReCap Photo?
Message 6 of 16
gerald_chin
Hi @michael.reuter,
I would like to apologise for the confusion.
To import into ReCap Photo, you would need to use the "Scan to Mesh" feature on ReCap Pro. And subsequently, import the mesh file into ReCap Photo and export it to XYZ format.
Cheers,
Gerald Chin
Autodesk Vault
Message 7 of 16
joe_truitt
So I will have to use the Cloud scan to mesh to create a format that will open in recap photo and then export from that.
That might be good for something small, I have 4 RCP file groups that are roughly 40gigs of data total. This does not seam very efficient or cost effective.
recap Photo will also have to process this in the cloud?
if i process this much data on the cloud how long and how much are we talking.
is this the only way?
Thank you
Message 8 of 16
anil_mistry
Autodesk Support
Autodesk Support
Hi @joe_truitt,
Thank you for participating in our community! Yes, once you create Mesh you can download output in RCM format then open in ReCap Photo. Unfortunately ReCap Photo only process in cloud at this time and we don't know how log it will take to create Mesh for individual project. Its all depends on the project.
If you have any feedback that you would like to submit regarding any enhancement, please click on the “ReCap IdeaStation” link on the ReCap community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Anil Mistry
Message 9 of 16
Not that the Scan to mesh function has been taken away, are you going to update your method to recap to recapphoto
Message 10 of 16
So how do we go about doing this now that you got rid of the scan to mesh feature.
Message 11 of 16
jimJB8UC
Bump.  I'd like to see an answer to this too.
Message 12 of 16
My Workflow would be:
  1. Export from ReCap as .e57 or .pst file
  2. Import to a Software like cloudcompare or meshlab (all open source)
  3. Optional create mesh
  4. Save as .obj, .ply
  5. Import to ReCap Photo
Message 13 of 16
You can save  .xyz-file directly from cloudcompare.
Message 14 of 16
How can I export .xyz-file directly from cloudcompare?
Thx
Message 15 of 16
If you got a pointcloud load in cloudcompare, klick the save button and choose ASCII Cloud as fileformat.
Message 16 of 16
Thanks!
