After loading my aerial photos to Recap and click "Create" I get this message: "Not enough space for uploading files and processing Please clean up your space and try again"
Not sure what to "clean up" the create file is about 3.5 megs, my computer has 235 gigs....what am I missing?
Solved by jayson.sterba. Go to Solution.
Hi @Anonymous,
This error message should be referencing your A360 drive.
Please go to a360.autodesk.com/drive, sign in and see if you have free space there.
Thank you!
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @jayson.sterba provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
hi @Anonymous,
This is atypical behavior if the photos are in focus and provide good overlap you should not see blurry models.
Im getting the same error. The solutions do not help. I dont have anything in my drive. Why are they making this software so hard to use.
Why do i need to deal with the drive? I never used to.
