Can you connect the kinect xbox 360 in Recap
Solved by vikas.vaishnav. Go to Solution.
Hello @j_cordero,
Thanks for writing to us. I am not aware of any method to connect Recap to Kinect xbox360. Can you share what is it that you want to achieve by connecting it? If you are looking to export 3d scenes for gaming purpose you can export FBX file type from Recap Photo to import them in Unity or other game engines that might connect to Kinect.
Hope this helps.
Hi @j_cordero,
I'm just checking in to see if you need more help with this. Did the suggestion that @vikas.vaishnav provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
