ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Blue screen / crash
4 REPLIES 4
Scanner2GO
451 Views, 4 Replies
Blue screen / crash
Hi Guys,
I am getting a blue screen while working with Recap. Somtimes it is crashing during the import and somtimes during the auto registration or the indexing process.
Is there a kind of dump file to get a better understanding of the issue?
Scanner2GO
4 REPLIES 4
MarcZinck
in reply to: Scanner2GO
I'm sorry to hear that you are having problems when using ReCap Pro. Could you provide us with more details regarding your system configuration? (Computer model, OS version, disk, ram, graphics card, etc...)
From your description and photo it appears that the operating system is experiencing a non-recoverable failure which may be due to out of date drivers.
Do you have sufficient free disk space for the project? You may want to try using an external drive as an experiment.
Marc
Scanner2GO
in reply to: MarcZinck
Hi Marc,
sorry for my late response but I was working on another job. At the moment recap is working fine. But I will keep testing it for our clients.
Regarding your point of disk space. Is there a way to estimate if I have enough disk space?
Cheers,
Eike
Hi @Scanner2GO
can you check if the Recap system requirements are met with your computer?
http://help.autodesk.com/view/RECAP/2017/ENU/?guid=GUID-3F668434-36E4-4427-AC34-41ACA356AFAA
I have seen all kinds of errors or program crashes, but it's the first time I see a blue screen.
Karsten
Karsten Saenger
Hi Karsten,
I am working on a Surface PRO 4 with 16GB Ram and 512GBSSD Drive on a i7. My grafic card is weak with an Intel Iris Graphics 540.
Cheers,
Eike
Rail Community
