Autodesk Recap .RCP file to Editable 3D Solid
jacksontan818
jacksontan818
Does anyone know how to convert the .rcp format to Editable 3D Solid?
elan7LLGW
Nope. There used to be a convert to mesh feature but that was removed about 6 months ago without explanation.
Tomislav.Golubovic
There are two choices here for you.
1. Inside AutoCAD there are some basic tools to create objects from the Point Cloud.
2. There are two third party tools that come to mind. One is Faro As-Built which will convert the Point Cloud to a model. It works inside AutoCAD or Revit. The second is Edgewise, a product from Clearedge which will also convert the point cloud, but it does it in its own software, after which you then export to a file format you want.
andrijB4KHE
Community Visitor
Community Visitor
it is important for me.
i use 3d scaner
