Message 1 of 1
Autodesk ReCap / Autodesk ReCap Pro Update version 5.0.3.58 - Release Notes
Thank you for downloading Autodesk® ReCap / Autodesk ReCap Pro Update version 5.0.3.58
This release note contains the latest information regarding the installation and use of this update. It is strongly recommended that you read this entire document before you apply this update to your product. For reference, you should save this document to your hard drive or print a copy.
This update contains the following:
Fixes:
- Fix issue where Faro raw scan cannot be colorized if there is space in raw scan file name.
- Fix issue where intensity is not exported in exported .rcs files.
- Fix issue where some points disappear after loading project with user defined coordinate system.
- Fix issue where application crashes on loading project with missing scans.
- Fix issue where application crashes when failing to load ReCap codec plugins.
- Fix issue where application crashes when registering partial E57 scan.
- Fix issue where application crashes during checkerboard target extraction.
Improvements:
- Allow customer to set project CS if current project CS has not been set before (Only works with .FLS files).
- Support TLS1.2 for ReCap.
Changes:
- Remove scan-to-mesh beta feature from ReCap.
- Remove project clean-up beta feature tool from ReCap.
The release notes for this update are available at:
https://up.autodesk.com/2019/RECAP/AutodeskReCap_AutodeskReCapProUpdateVersion5.0.3.58-Readme.html
Users who have ReCap/ReCap Pro version 5.0.2.41 installed can apply this update in one of the following ways:
- Can install the update via Autodesk Desktop App OR
- Download and install the update from the following link: https://knowledge.autodesk.com/sites/default/files/file_downloads/ReCap_Update_v5.0.2.41_to_v5.0.3.5... OR
- The update will be available for download on AKN's ReCap section: https://knowledge.autodesk.com/support/recap/downloads
Anil Mistry
Technical Support Specialist
