In photo project, after building the 3d model, is the recap provide aerial trinagulation report with the solution accuracy, properties, and etc?
I saw an XML, but couldn't understand it.
Is there is an explanation of the output report?
Solved by koh.naimin. Go to Solution.
Hi, no I didn't saw any report. Also, the original scan has 150scans. I kept 4 scans to minimize the size of the project. Maybe the report came from this. Also, we got the same issue from 3 other projects.
Hello shay.sosko,
If you chose the aerial photo reconstruction, you should see the report folder as part of the outputs. Please refer to the .html file inside the report folder for a more human readable view of the reconstruction accuracy and quality.
The report.xml you discovered is primarily used by partners who wish to parse these data themselves for their pipeline.
Naimin
