- Mute
- Permalink
- Report
Hello everyone,
I'm having the following issue:
With my current project, i have to add survey points in my pointcloud.
To do this i've followed our usual workflow:
- Registrate/build the project in Scene
- remove unwanted points
- Load the Scene project into Recap to create the pointcloud
After it's done processing/indexing i always update the origin.
The next step is to register the survey points.
After registering all the survey points, the pointcloud doesn't appear to be in the correct height.
The 3 images attached to this post should clear that up, the RecapSurveyPoint is the original point placed by me, in which i have copy pasted the coordinates provided to me with the Autocad file (see AutocadHeight).
Should the Z value be the same or should it be an average of all the survey points on this side of the building?
I've also put the pointcloud in Revit and tried to measure the Z height there (and if this was correct), however i couldn't find an way to do this.
Is this also possible?
Thanks in advance!
Niels
