Autodesk ReCap File Formats – Which, Where & How?
vidanom
Autodesk Autodesk
vidanom
1.Supports all laser scan data
Hi folks!!!
Many of you who have come across a 3D laser scan data or digital photogrammetry models have probably wondered about all the new file formats. “What created them”, “What do they represent”, and most importantly, "How we can use them" and "Which product do I use them in"?
069159-black-paint-splatter-icon-alphanumeric-question-mark3
In this article, I’ll try to explain briefly all the file formats that the Autodesk ReCap product can read and export.
So let’s start.
First, scan alignment with ReCap 360 Pro:
ReCap
ReCap 360 Pro is an in-product enhancement to ReCap that dramatically improves the quality and efficiency of laser scanning projects with target-less registration, the process of aligning scans together without markers. To align, or if you prefer to register scans with ReCap not only you need the "Pro" version, but ReCap also requires that your scan data is structured. Well, “What is structured scan data”?
P9_faro_w_targets_02
Structured scan data is mainly coming from Faro, Leica, Z+F, Riegl, Topcon & Trimble 3D laser scanners in the format of .FLS, .PTG, PTX, ZFS, CLR, RSP and RDBX scan files respectively. These file formats, and some types of binary E57 scan files, are primarily structured scan data. It's a way that the scan data is stored from the hardware that ReCap can use to:
   - Register/align scan data.
   - Add survey points.
   - Convert points into mesh model.
   - Run auto cleanup tool.
   - View the scans in "Panorama" mode.
   - Publish scans on the cloud and share by using RealView on recap360.autodesk.com
Capture
RealView on ReCap 360 is an online service that provides scan viewing, sharing, measurement, and annotations (including hyperlinks).
   This laser scan data that is recorded by terrestrial 3D scanners can then be imported by ReCap in a 3D panoramic representation that is both visually compelling as well as measurable. These panoramas are excellent communication tools for conveying the real-world conditions of a scanned environment without having a physical presence.
   All the other scan file formats that ReCap can import cannot be used for the mentioned features above. However, unstructured scan data can still be used for all the available capabilities within the product like import, editing, measuring, tagging, exporting, etc...
More technical information around ReCap 360 can be found under the recap knowledge network page.
For more news make sure to subscribe to our blog Subscribe to Reality Computing Blog or follow us on our channels Join LinkedIn Reality Computing Group  Join Reality Computing Google+ Page  Subscribe to Reality Computing YouTube Channel
trutherfordLUGUE
Will  you be able to support .JXL files soon?
Ted Rutherford
anil_mistry
Autodesk Support
Autodesk Support
Hi @trutherfordLUGUE,
Thank you for participating in our Community! At this time there are no plans to support .JXL format files.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
