rail turnouts
rail turnouts
gibbpt
Message 1 of 18
rail turnouts
gibbpt
hi,
can some one direct me how to create turnouts of COGIFER, to use in projects here in Portugal?
they had a Radius and Spiral ( Clhotóide)
thanks,
MT
Accepted solutions (3)
Replies (17)
Message 2 of 18
SoaresASBCAD
You must choose the options right at the beginning
ASoares
Message 3 of 18
gibbpt
sry not understand...
Message 4 of 18
camilo.jimenezH5AC8
Deixo aqui alguns links com informações que podem te ajudar:
Autodesk Civil 3D Ajuda | Para criar um AMV | Autodesk
What's New in Civil 3D 2022.1 : Rail Switch and Crossing Geometry - YouTube
CIVIL 3D TURNOUT COMPARISON TOOLS VERSIONS - YouTube
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Did you find this post helpful? Then feel free to give likes to this post!
Was your question successfully answered? Then just click on the 'Mark it as solution'
Camilo Jiménez
Infrastructure Technical Sales Specialist
Spain & Portugal
Message 5 of 18
heidi_castellanos_leyra
Hi @gibbpt
Just to be clear, when you say radius and spiral, are you talking about the diverted track geometry ? inside the turnout? or the bending method?
I'll try to answer the clearest way possible, dont hesitate to reach if not clear enough.
For adding a model in to an existing catalog, you have to modify your Json file located here C:\ProgramData\Autodesk\C3D 2024\enu\Data\Railway Design Standards\Turnout, know that by default you have 3 precharged catalogues (French/US/Generic)
What I can advise, is to try to add a new model in to the French Catalog to see if this calculation method can fit your requirements.
If you were talking about curves and spirals as bending method, C3D does not support bending in spirals for the moment.  And for bending in curves, it supports the French bending method. Just be sure how does the Portuguese  method calculates the bending 😉
If you were talking about the interior geometry you'll have to modify the expression file  at the same location. Today the calculation for diverted line geometry supports, tangent (one radius) calculation of diverted track, or secant (two, with a degree of non tangency).
Give a try adding a new model ! Let us know how it went !
Message 6 of 18
snoyola
this video may give a little tip
https://www.youtube.com/watch?v=l7h2CGWmV8A
Simon Noyola Rivero
BIM Infrastructure SME
Digital Drafting Systems
Autodesk Authorized Consultant
Subject Matter Expert Civil&Map
Civil 3D Country kit  development
Autodesk Certified Instructor
USA Mexico, Central America, Caribbean & Venezuela
www.linkedin.com/in/simon-noyola-rivero-29551410
https://www.youtube.com/user/snoyolar
Message 7 of 18
gibbpt
hi,
many thanks , yes  the diverted track geometry  inside the turnout
thanks
Moises
Message 8 of 18
gibbpt
thk
Message 9 of 18
Hi @gibbpt, found some API expressions to add clothoids to the diverted line geometry
Notice that there can be 3 types of spiral parameters :
- Spiral length (`length`)
- Spiral A value (`avalue`)
- Spiral angle (`angle`)
An the expressions are the following :
func_cache_simple_spiral_with_type_startpt_startdir_radius_param_paramtype_inout_cw('clothoid', x, y, dirx, diry, radius, length, 'length', 'in_curve', 'cw')
func_cache_simple_spiral_with_type_endpt_enddir_radius_param_paramtype_inout_cw('clothoid', x, y, dirx, diry, radius, length, 'length', 'in_curve', 'cw')
func_cache_simple_spiral_with_type_startpt_startdir_endpt_inout('clothoid', x1, y1, dirx1, diry1, x2, y2, 'in_curve')
func_cache_simple_spiral_with_type_endpt_enddir_startpt_inout('clothoid', x2, y2, dirx2, diry2, x1, y1, 'in_curve')
unc_cache_compound_spiral_with_type_startpt_startdir_startradius_endradius_param_paramtype_cw('clothoid', x1, y1, dirx1, diry1, radius1, radius2, length, 'length', 'cw')
func_cache_compound_spiral_with_type_endpt_enddir_startradius_endradius_param_paramtype_cw('clothoid', x2, y2, dirx2, diry2, radius1, radius2, length, 'length', 'cw')
Message 10 of 18
gibbpt
many thanks,
is there a place where we can find all API expressions?
many thanks
Moisés
Message 11 of 18
gibbpt
hi again,
sorry for take your time, is there an API expression to create GOGO points, i need them to create a table for turnout in drawing.
many thanks,
Moisés
Message 12 of 18
gibbpt
hi again, im using func_cache_compound_spiral_with_type_startpt_startdir_startradius_endradius_param_paramtype_cw('clothoid', x1, y1, dirx1, diry1, radius1, radius2, length, 'length', 'cw'), and solve my problem, but i had a problem, not able to find the way , after create the arc not able to get dirx1 and diry1 of arc at that point in order to a correct creation of spiral.. if possible to help i apreciate...
many thanks,
Moisés
try to use func_direction_on_cached_curve_at_param(index, param) but not understand how to use it to get that dirx1 and diry1, thanks again
Message 13 of 18
Hi @gibbpt
try  after using func_direction_on_cached_curve_at_param(index, param), use func_coord_from_string to find coordinates dirx1 and diry1
See example :
            var EndDir := func_direction_on_cached_curve_at_param(ArcElement, 0.0);
            var EndDirX := func_coord_from_string(EndDir, 0.0);
            var EndDirY := func_coord_from_string(EndDir, 1.0);
hope it helps
Message 14 of 18
Not for the moment with turnouts, but hope they will be soon API for turnout critical points :), for the moment the only option its to manually create cogo points in the critical points and then create your PE report
Message 15 of 18
gibbpt
many many thanks,
all the best to you 🙂
Moisés
Message 16 of 18
gibbpt
so perfect 🙂 thanks
just in case someone try / need to use i use, var EndDir := func_direction_on_cached_curve_at_param(ArcElement, 1.0); to get end of arc as i draw it from JP to CM direction.
all the best,
Moises
Message 17 of 18
en.foladi
Thanks. I have probloeme with basic T Out Design in civil 3d 2022.
Message 18 of 18
jose_coimbras1
Hi, can you solve the ptoblem? I´ll try also put the cogifer geomety in civil3d 2025. But we also had the "detail" of the alignment should only starts at end of turnout... i guesse i need other aproach.
