Hi @gibbpt,
Just to be clear, when you say radius and spiral, are you talking about the diverted track geometry ? inside the turnout? or the bending method?
I'll try to answer the clearest way possible, dont hesitate to reach if not clear enough.
For adding a model in to an existing catalog, you have to modify your Json file located here C:\ProgramData\Autodesk\C3D 2024\enu\Data\Railway Design Standards\Turnout, know that by default you have 3 precharged catalogues (French/US/Generic)
What I can advise, is to try to add a new model in to the French Catalog to see if this calculation method can fit your requirements.
If you were talking about curves and spirals as bending method, C3D does not support bending in spirals for the moment. And for bending in curves, it supports the French bending method. Just be sure how does the Portuguese method calculates the bending 😉
If you were talking about the interior geometry you'll have to modify the expression file at the same location. Today the calculation for diverted line geometry supports, tangent (one radius) calculation of diverted track, or secant (two, with a degree of non tangency).
Give a try adding a new model ! Let us know how it went !
