Hi everyone working on Project Falcon. I just tried the tool and I really like the idea. Congratulations on the first release, and thank you for working on such a tool.
Are you planning to improve the Cut Tool? For example, I like how this tool works in 3D-Coat.
I recorded a video for you showing how it works there. I’d like to see it improved in a similar direction.
https://www.youtube.com/watch?v=Zjk1IprPcTs
Timing:
0:00 - First, you can adjust the angle smoothing of these line corners and build some kind of cutting profile, instead of just cutting along a single line.
0:14 - Showing an example of a more complex profile.
0:36 - You can also adjust the profile depth, for example if you want to make small cuts with a specific depth.
1:22 - Finally, I show an even more complex curve profile.
Thank you and have a great day
Best regards,
Andrew.
