Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Sudden shutdown when i try to change settings
1 REPLY 1
T.Groot3245
235 Views, 1 Reply
Autocad LT 2012 on Windows 10. Stand alone.
Until now now problems i cold not solve by myself!
When I open the settings menu the program shuts down and returns the popup for reporting the problem to Autodesk.
This brings no answer.
Tags (1)
1 REPLY 1
pendean
in reply to: T.Groot3245
LT2012 is not supported in Win10Pro: Autodesk will never ever help you find a fix. Sorry.
Best thing to try is to remove whatever Win10 and other software updates/installations took place before it all broke and hope for the best.
You could also try this tip https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Starting...
Or these tips too http://www.howtogeek.com/228689/how-to-make-old-programs-work-on-windows-10/
Administrator Productivity
