I am upgrading a computer at my company and the user's old computer has a copy of AutoCAD LT 2014. I have the license number and information and I'm trying to figure out how to get the program on the new computer. The user is the only user so buying another updated license is unnecessary and out of the budget. I believe the previous version was installed via a CD or usb drive or something but that is nowhere to be found. Is there anyway I can get it on the new computer? I have tried creating an autodesk account and syncing that with Autocad LT 2014 but it won't open autodesk 360. Any help is appreciated.
Solved by natasha.l. Go to Solution.
Step I - You will need some sort of install media, and you will not find the download from Autodesk.
Step II - if you find the install media, do you have a valid serial number?
Hello @Anonymous,
You can attempt to install a legacy version on a newer operating system. I would like to make you aware that it very likely will present the user with performance issues, please review the system requirements for the application before attempting this.
You can use the stored activation information you have to activate. If you need an activation code it is still available for stand-alone perpetual licenses, please request one >activation code<.
Please keep in mind due to our Product Lifecycle, Autodesk does not offer product activation or installation support for products that are not on the eligible previous version list for subscriptions and maintenance plans.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
You can attempt to install an legacy version on a newer operating system. I would like to make you aware that it very likely will present the user with performance issues, please review the system requirements for the application.
We still run Civil 3D 2014 on Windows 10, with no issues. I think @Anonymous main issue is going to be acquiring the install media/download.
You are registerd a the "owner" of a 2014Lt licence?
Then login with this account < https://manage.autodesk.com/cep > and download LT2014 via "Browser Method"(best choice)
Sebastian
Contact Autodesk support to check your serial number, the license could have since been traded in for subscription.
If it is a perpetual license and Autodesk is feeling generous, they will generate a download link for you. Good luck!
You can open a ticket with Licensing support and confirm your options here https://knowledge.autodesk.com/contact-support/installation-activation
