Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
AutoCAD 2010 download
26 REPLIES 26
Message 1 of 27
71472 Views, 26 Replies
Hi guys
Can someone please tell me from where to download " AutoCAD 2010 ". In this website I have searched everywhere but can't found it. It offers to download AutoCAD 2011 - 2014 but I want to download 2010. If anyone knows, please help me.
Thanks.
26 REPLIES 26
Message 2 of 27
joane.bonghanoy
Hi imtiaz.lalani,
Refer to the links below to download AutoCAD 2010.
           - AutoCAD 2010 - 32 bit
           - AutoCAD 2010 - 64 bit
Joane Bonghanoy
Message 3 of 27
in reply to: joane.bonghanoy
Thanks Joane 🙂
Message 4 of 27
How about the down load for the 2010 English version? I have a couple of lighting software programs that I need the 2010 version.
Message 5 of 27
philip.s
Welcome to the community Ron!
You can access most current + previous supported version download links (including AutoCAD Civil 3D 2010) through Matt, our Virtual Assistant.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Should you run into an activation error, typically resulting from an upgraded license and or reaching the activation limit on a given license, our License Assistance Team would be able to help facilitate an activation code.
Please accept as a solution if this fully answers your inquiry, or reply with additional questions as needed.
Message 6 of 27
in reply to: philip.s
I had AutoCAD 2010 on my PC and the hard drive crashed.  How can I reinstall it on my new hard drive?
Message 7 of 27
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
In the same way you installed it on your previous one .... start the setup from your installation media.
Maybe I missed something in your question?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 8 of 27
Mark.Lancaster
@Anonymous
Welcome to the community.
If you don't have the original media than you most likely out of luck.  2010 is retired and no longer support by Autodesk, thus there's no live download for this version.  In addition I assume since your hard drive failed that you installed a newer OS, is that correct?  If so the 2010 version is not going to work on that either.
Mark Lancaster
Message 9 of 27
Hello Mam the the serial no of autocad 2010
Message 10 of 27
What?
Message 11 of 27
Alfred.NESWADBA
@Anonymous
You have got it when you bought AutoCAD.
No one here in the forum can know your serial number.
- alfred -
Alfred NESWADBA
Message 12 of 27
mdavis22569
@Anonymous
Doesn't matter if you get one ..it can't be activated:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-version-support-change.html
What about products that didn’t use the year as a version (for example, R10)?
All products using a non-year version scheme are included in the v2010 or earlier set of releases and can no longer be activated after August 31, 2019.
Mike Davis
Message 13 of 27
yes
Message 14 of 27
Message 15 of 27
mdavis22569
@Anonymous
The person you tagged for help doesn't work for Autodesk anymore
This is an old thread and AutoCAD 10 isn't able to be activated anymore
Mike Davis
Message 16 of 27
hi can i ask the product key Autocad 2010 64 bit thank you
Message 17 of 27
pendean
Did you even try a web search? Google put this up at the top of the search page https://knowledge.autodesk.com/customer-service/download-install/activate/find-serial-number-product...
Message 18 of 27
mdavis22569
https://knowledge.autodesk.com/contact-support/websupport/finding-download
But you likely won't be able to activate it @Anonymous
Mike Davis
Message 19 of 27
bgairola
What is serial no. & product key of Autocad 2010 64 bit?
Message 20 of 27
Alfred.NESWADBA
in reply to: bgairola
Sorry, how should anyone in the forum know what is your serial number? You have bought it, so you are the one who can know that.
The product key for AutoCAD 2010 is 001B1
- alfred -
Alfred NESWADBA
Administrator Productivity
