Autocad 2007 activation code
kmtroxel
kmtroxel
so your telling me there is no way to activate a program that i bought a perpetual licence for and have kept up with the maintenance all these years.  this is critical to my operation and there is no need to upgrade other than you won't give me a auth code!!!
mdavis22569
Hi @kmtroxel
As I believe you know
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
If my current network licensing file includes products which are v2010 or earlier, will I be able to get an activation code?
No. Product version is validated during the activation process. Versions 2010 or earlier cannot be activated.
Do you have a PC with XP or W2000 ?
Mike Davis
kmtroxel
i am running a windows 10 computer...  i installed longbox and the autocad 2007 ran fine thru the trial 30 days while i tryed to get the auth code.  now my business is down.  autocad 2007 drives the software that is the center of our operation.
RobDraw
What's plan B? You must have seen this coming if you were maintaining your license. 30 days should have been plenty of time for you to figure out that you were going to eventually be in this situation and come up with a backup plan.
Rob
