Autocad Architecture 2010
I have been using this version for sometime now on a Win 10 machine. Windows did a new update last night and updated to win 10 ver 1909. Now it is asking for activation code. When trying to get one. It states Registration-Activation Error (0015.111). What can I do?
pendean
Community Legend
Community Legend
Your AutoCADARCH 2010 is not supported in Win10, which means Autodesk is not interested ever in helping you with any issue, it does not mean anything else you might read into "supported" http://autode.sk/1IY4C2X
Autodesk also ended automatic reauthorizing of 2010 and older software as of August 31 2019, read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline.
If you still have your old Win7 PC and all works well, hang on to it for as long as it will last, then figure out a new option if you are unable to join Autodesk Subscription for newer software. If you find Autodesk software subscriptions too expensive, there are many other CAD packages out there with no subscription options (initial cost may still be comparably high) that you can go get and use.
