Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
AutoCAD 2002 Network License Issue
2 REPLIES 2
965 Views, 2 Replies
Hi all,
my company is setting up a testing PC to test and see if the Autocad 2002 license file works on a different PC.
It has been found out that the license file is locked to the current server with a signature keycode.
We have no record as to who is the previous administrator or manager that purchased this license back in 2003.
I hope someone from AutoCAD can assist on how to regenerate the license file to allow it to work on new PC.
The AutoCAD license comes with a parallel port license dongle that is already plugged into the testing PC.
I've replaced some real details with xxx due to privacy.
The error message as attached from the lmtools.
10:26:20 (adskflex) Invalid license key (inconsistent authentication code)
10:26:20 (adskflex) ==>INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 82 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
ISSUED=15-sep-2003 SN=XXX-XXXXXXXX SIGN=XXXXXXXXXXXX
10:26:20 (adskflex) License server system started on xxx-xxx
10:26:20 (adskflex) No features to serve, exiting
10:26:20 (adskflex) EXITING DUE TO SIGNAL 27 Exit reason 4
xxx-xxx: license server UP (MASTER) v11.16.2
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: xxx-xxx
License path: 27000@xxx-xxx;
FlexNet Licensing error:-97,121
some details on the license file below
part of debug.log details
10:26:20 (lmgrd) (@lmgrd-SLOG@) ===============================================
10:26:20 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
10:26:20 (lmgrd) Starting vendor daemons ...
10:26:20 (lmgrd) Starting vendor daemon at port 2080
10:26:20 (lmgrd) Using vendor daemon port 2080 specified in license file
10:26:20 (lmgrd) Started adskflex (pid 5404)
10:26:20 (adskflex) Unable to initialize access to trusted storage: 1
10:26:20 (adskflex) FlexNet Licensing version v11.16.2.0 build 242433 i86_n3
10:26:20 (adskflex) SLOG: Summary LOG statistics is enabled.
10:26:20 (adskflex) SLOG: FNPLS-INTERNAL-CKPT1
10:26:20 (adskflex) SLOG: VM Status: 0
10:26:20 (adskflex) SLOG: FNPLS-INTERNAL-CKPT5
10:26:20 (adskflex) SLOG: TPM Status: 0
10:26:20 (adskflex) SLOG: FNPLS-INTERNAL-CKPT6
Tags (1)
2 REPLIES 2
The license file is locked to the particular PC, you can regenerate license from the Contract Manager's Autodesk account or request Autodesk support to do it for you.
But as it's a 2002 product they will probably refuse to do so because singe 31 Aug 2019 activation of product versions 2010 and older is not supported anymore:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Thanks for the clarification and the links.
Administrator Productivity
