Software for installing autodesk bulding design suite premium 2015, in particular Revit 2015
vitis
Observer Observer
Message 1 of 9
vitis
Observer
Observer
Original Title: Software per l'installazione di autodesk bulding design suite premium 2015, in particolare Revit 2015
Salve sono in possesso di una licenza permanente di autodesk bulding design suite premium 2015 con numero di serie prodotto, installata su un computer windows 7, computer che ora devo cambiare. L'installazione mi serve per un nuovo computer windows 11.
L'installazione in mio possesso, non so perché, non è uguale a quella installata e risulta essere revit 2015 structural
Translation added by @ForumCommunityManager using DeepL.com:
Hello I am in possession of a permanent licence of autodesk bulding design suite premium 2015 with product serial number, installed on a windows 7 computer, a computer that I now have to change. I need the installation for a new windows 11 computer.
The installation I have, I don't know why, is not the same as the one installed and it turns out to be revit 2015 structural.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@vitis No one here is Autodesk, and your software is not designed to work in Win11 so Autodesk will never grant you access sadly. Sorry.
You need to purchase new software for your new Win11 computer today.
Message 3 of 9
vitis
Observer
Observer
MA PENSO SIA MIO DIRITTO AVERE IL SOFTWARE DI CUI HO UNA LICENZA PERMANENTE.
COSI' POTRO' EVENTUALMENTE INSTALLARLO SU UN COMPUTER CON VERSIONE WINDOWS
FUNZIONANTE CON LA MIA VERSIONE PERMANENTE.
IL PROBLEMA E' CHE ORA IL SOFTWARE CHE HO NEL MIO ARCHIVIO E' UNA
INSTALLAZIONE DI REVIT STRUCTURE IO INVECE HO INSTALLATA UNA LICENZA
PERMANENTE DI REVIT ARCHITECTURE.
Message 4 of 9
STEFANOVITI3492
Community Visitor
Community Visitor
COSI' POTRO' EVENTUALMENTE INSTALLARLO SU UN COMPUTER CON VERSIONE WINDOWS FUNZIONANTE CON LA MIA VERSIONE PERMANENTE.
IL PROBLEMA E' CHE ORA IL SOFTWARE CHE HO NEL MIO ARCHIVIO E' UNA INSTALLAZIONE DI REVIT STRUCTURE IO INVECE HO INSTALLATA UNA LICENZA PERMANENTE DI REVIT ARCHITECTURE
Message 5 of 9
pendean
Community Legend
Community Legend
@STEFANOVITI3492 That's between you and Autodesk, no one here is Autodesk nor Autodesk Licensing, so continued posting about it here leads to nothing and does not change anything sadly. Sorry.
Message 6 of 9
STEFANOVITI3492
Community Visitor
Community Visitor
AUTODESK, UNA VOLTA POSTO IL PROBLEMA, MI HA CONSIGLIATO DI POSTARE IN QUESTO FORUM PER RISOLVERE IL MIO PROBLEMA.
SCUSATE PER IL DISTURBO, MA QUI RIBADISCO MI HA MANDATO AUTODESK.
ANCHIO AVEVO INTUITO CHE PARTECIPARE A QUESTO FORUM SAREBBE STATO INUTILE...GRAZIE IN OGNI CASO
Message 7 of 9
pendean
Community Legend
Community Legend
@STEFANOVITI3492 They sent you here to avoid dealing with you. Everyone here is an end user, a customer of Autodesk. Customers cannot authorize software on their own, if they could, you you not be asking but doing it yourself.
Again, whomever you talked to sent you over here because they wanted you to move on and not bother them. How do you say that in Italian, Farabutto!
Message 8 of 9
STEFANOVITI3492
Community Visitor
Community Visitor
TI RISULTA CHE IL SOFTWARE DI REVIT ARCHITECTURE CHE SI TROVA IN RETE REGOLARMENTE VENDUTO, COSÌ ALMENO DICONO, A 80/100€ SIA FUNZIONANTE?
Message 9 of 9
pendean
Community Legend
Community Legend
@STEFANOVITI3492 No idea, I don't have a need to do that. Generally those kinds of deals are about taking your money instead of providing you with legitimate software since only Autodesk can activate it.
