Revit 2017 activation code
please I wanna serial number for revit 2017
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is a user forum and users don't send other users serial #s for the product.  Serial #s come from Autodesk when your subscribe to (paid for) the product or you are a student attending a qualified educational institution.
Where do you fall under?
Mark Lancaster
natasha.l
Hello @sasoooooo,
Welcome to the community.
To activate you should review the information below:
  1. If, you are eligible for Educational Software Create an Account
  2. Review the Steps for Setting-Up Student Software, the educational site will provide the Serial # & Product Key
note: added this info for you
  1. Depending on the download method it will automatically recognize your credentials & sign-in or you manually type in the serial# & product key (you shouldn't need an activation code)
  2. Temporarily disable security settings like Antivirus, Firewall & UAC on your Windows operating system
  3. An internet connection is required to activate, every 30days you should be connected to the internet at some point (to verify your license & use the software) Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection. You can try another Wifi network location
  4. If the online method does not work & you need an activation code for offline activation, request one here by using Register.autodesk.com
Thank you for posting & let us know if you need some more help activating.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello sasoooooo,
I wanted to check-in with you, please review the last post it runs through everything you will need to set up your educational software.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
sabariarmy08
Community Visitor
Community Visitor
prodect key and serial number
sabariarmy08
Community Visitor
Community Visitor
