Problemi installazione Building Design Suite Premium 2015 / Installation problems with Building Design Suite Premium 2015
marco15
Message 1 of 9
marco15
Sto cercando inutilmente di installare il software su un nuovo laptop con windows 11.
al termine dell'installazione compare l'errore contenuto nello screenshot allegato.
L'assistenza Autodesk mi ha indirizzato qui. Qualcuno mi sa per cortesia suggerire una soluzione?
Grazie
Translation:
I am unsuccessfully trying to install the software on a new laptop with Windows 11. At the end of the installation, the error shown in the attached screenshot appears. Autodesk support directed me here. Could someone kindly suggest a solution? Thanks
@marco15 - moderator has edited this post to provide for translation. Please use a translator to post in English.
Replies (8)
Message 2 of 9
paullimapa
2015 version does not support Windows 11
Perhaps if you can downgrade to Windows 10?
Paul Li
IT Specialist
@The Office
Message 3 of 9
marco15
I'm no expert, but I don't think it's possible. I'm installing it on a newly purchased laptop with Windows 11 preinstalled.
Message 4 of 9
paullimapa
Then it looks like you have the following options:
1) pay subscription for latest AutoCAD or Revit which installs fine on Windows 11
2) purchase a computer that has Windows 10 installed so you can install the older 2015 BDSP version
3) look for computer technician that can help you downgrade your Windows 11 OS to Windows 10 so you can try installing 2015 BDSP
After successful installation then you can upgrade it back to Windows 11 and hope that 2015 BDSP still runs...
here's another recent thread has similar discussion but with AutoCAD 2015 and Windows 10 vs 11
https://forums.autodesk.com/t5/autocad-forum/2015-definitely-works-fine-on-window-11-but-how/td-p/11...
Paul Li
IT Specialist
@The Office
Message 5 of 9
marco15
If I can downgrade to Windows 11, will Autodesk then send me the activation codes?
Message 6 of 9
paullimapa
That's going to be another hurdle since Autodesk ended support and activation for 2015 back in March of this year:
https://acadsystems.com/autodesk-end-of-support-for-2015-and-2016-versions-license-transfer-utility-...
There's a similar discussion also here:
https://forums.autodesk.com/t5/previous-version-support-forum/request-for-activation-perpetual-autoc...
Paul Li
IT Specialist
@The Office
Message 7 of 9
marco15
Non resta che promuovere una classe action contro Autodesk per sospensione di licenze vendute come perenni
Message 8 of 9
pendean
Community Legend
Community Legend
Whip out a credit card and hire a lawyer: no one has ever won in 40+years but your luck will be very different I'm sure.
Message 9 of 9
marco15
Alla fine, insistendo adeguatamente con valide motivazioni, il supporto Autodesk invia ancora i codici di attivazione er i prodotti 2015. Ho quindi creato una partizione win10 sul laptop e installato e attivato la suite 2015. Ringrazio Paul Li per il prezioso supporto.
