Help with AutoCAD LT 2005
harryram2
harryram2
My Name is Harry N. Ramchattar and I have in my position AutoCAD LT 2005 Serial No. xxx-xxxxxxxx  When I try to start the program a page pops up saying (This program has known compatibility issues) and in a box it says (Check solution online) I need some help with this issue. Thank you.
RSomppi
Even if you get it to start, you won't be able to get a new activation code. Autodesk stopped supporting older versions.
m_latz
I'm not sure if I understand you correct, but what happens, that AutoCAD LT did not work anymore ? Windows update from to ?
regards
Markus
