Fatal Error occurs when entering XREF command in AntoCAD LT 2013
- Mute
- Permalink
- Report
I encountered a fatal error message right after entering the XREF command for all files (AutoCAD 2013 LT version). The file closes even without popping up the xref window for selecting files to reference in. The files are not damaged because I can reopen the files and see everything is intact. For some reason the program just cannot execute the XREF command.
I tried to uninstall and reinstall the AutoCAD LT 2013 program (a purchased disk), but the problem remains, even with a blank file (new file) after entering "XREF". Then I followed the instructions on Autodesk trouble shooting website to download AutoCAD LT 2013 Service Pack 2, however, the problem still remains.
Background history:
I purchased a 2013 LT disk 10 years ago and used it until I subscribed 2022 LT version. However, I found out I could not use 2022, even 2020 and 2019 subscribed versions because I encountered a screen re-calibrate problem (screen keeps jumping up and down constantly due to lack of compatible built-in graphic card). I didn't renew after the 2022 subscription was expired in December 2022 and returned to use the purchased disk 2013 LT. Since then, it has been running great until 3/7/2023 when I got the fatal error message by entering XREF command for all files.
I reported to Autodesk in the pop-out window of the error message and the error report number is 701380286. Below are the images of the error messages. Thank you so much for helping! -Gloria
