Autodesk® AutoCAD® 2015-2018 Geolocation Online Map Hotfix
Message 1 of 17
Today I was asked to update my Geolocation Online Map or otherwise it would stop working after 6/30/2017. I applied the hotfix update and it was installed under C:Autodesk . The problem is that the hotfix didn't do anything and it still asks me to update my Geolocation everytime I try to turn on the maps for a drawing. I need help with this problem.. Thank you.
Replies (16)
Message 2 of 17
Cadologist
I got this notification the other day also for the hotfix. Link to the hotfix below (which includes detailed instructions). Not sure what the solution is to your question, however the link below will provide additional details....
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
Chad Franklin
Message 3 of 17
I already applied this hotfix and the issue I have is that it didn't do anything after the successful installation.
Message 4 of 17
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you attach one of your files to a post along with the map settings? Once the map is configured it should not keep asking for information.
I suggest creating a new, clean drawing and using the GeoLocation. Save the drawing and open it back up. Does it behave properly?
John Vellek
Message 5 of 17
pendean
Community Legend
Community Legend
So when I installed this hotfix (after closeing AutoCAD) it appeared like nothing happened, then I noticed the installer did not actually kick-in. Right-clicking on the download and selecting RUN AS ADMINISTRATOR seemed to finish the installation. it then took a few minutes to complete.
Testing in a new file seemed to show it installed correctly: I did not get a chance to use it on a previously completed "geolcated" files.
Message 6 of 17
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 7 of 17
jcrispo
Hello All,
I was having the same issue.  However, my issue was that after downloading the hotfix, if i clicked the file from the download window, Windows would open the file prior to extracting the file from the zip folder.  It made it appear that the file had been extracted.  Make sure you extract the exe. from the zip prior to running and then right click (as mentioned above) to run as administrator.
Message 8 of 17
Richard.Vivanco
Hi
Exist another method to download or install the hotfix?
This link doesnt work, the download doesnt start.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
Message 9 of 17
WarrenGeissler
Yep - the link is down. Try >>THIS<< page instead. It sounds like a manual process.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 10 of 17
Richard.Vivanco
Hi
Thanks for the response, it works OK even without js file (i dont found 2018 version of this)
Js files which type of function do?
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
Message 11 of 17
WarrenGeissler
I don't know what the js files do, but no worry. From that page:
Note:
There is no js folder for the 2018 version of AutoCAD/AutoCADLT.
Warren Geissler
Message 12 of 17
having same issue.  no fix.  being redirected to download this file
http://download.autodesk.com/us/support/files/genuine/Autodesk_AutoCAD_2015_to_2018_Geolocation_Onli...
which is an exe.  seems to instal but doesnt fix issue of asking me ...  is there a part 1 of the fix i am missing?
Message 13 of 17
gzunigaeduardoeF5NPV
Community Visitor
Community Visitor
Hola, buen día. Ya no funciona ese enlace, tiene otra opción?
Message 14 of 17
Cadologist
He encontrado otro enlace, sin embargo, la descarga también falta. Es posible que la corrección rápida ya no esté disponible. Estoy usando un traductor de español a inglés.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Deploy-Geolocation...
Chad Franklin
Message 15 of 17
pendean
Community Legend
Community Legend
@gzunigaeduardoeF5NPV @Cadologist Autodesk no longer provides downloads for any 2015-2018 tools and products today in the year 2026. Sorry.
Try 3rd party sites like https://www.cadforum.cz/en/download.asp?file=Geo
or other similar websites.
Message 16 of 17
din_ansari00
Community Visitor
Community Visitor
geolocation not working in autocadd file
Message 17 of 17
pendean
Community Legend
Community Legend
AutoCAD 2015-2018 are no longer supported, so that's to be expected today in the year 2026.
