AutoCADLT 2002 crashes every few minutes Windows 10
hoosac19
hoosac19
Hello, My AutoCADLT 2002 crashes every few minutes on my Windows 10 PC.  I get an "Internal Error: GEDIT3" message, followed by the screenshot attached, then the program closes.  I've also attached my Microsoft .NET Framework configuration if that is relevant.  I really like this program, used it daily years ago and it still does everything I want, and my old serial number, CD Key and activation code still work.  Might any Autocad LT users please have any suggestions on this issue?  Thank you very much!
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
pendean
Community Legend
Community Legend
LT2002 is not designed for Win10.
GEDIT3 is also a problem in LT2002, you have to find and install the update for LT2002 to remove the problem.
Nope, Autodesk does not store that anymore, you should have that or look for it on the web but beware of scams https://www.google.com/search?q=autocad+Internal+Error%3A+GEDIT3
Enjoy the ride.
hoosac19
Thanks for all the responses.  I used the Longbow Software converter to reinstall my AutoCAD LT 2002 software, this fixed all the Windows scripting errors.  They also assisted me with installing Autodesk’s SP2 patch, my issue has been resolved successfully.
